+ Reply to Thread
Results 1 to 9 of 9
Thread: Da3 questions
    Member menacer seems to know what they're on about menacer seems to know what they're on about menacer seems to know what they're on about
    Feb 2011
    gympie QLD
    DA9,DA3,EG,DA9
    Da3 questions
    Hey guys found a da3 might be able to get it cheap. Just wondering if they were actually released in Australia or import only. Also does much da9 stuff drop straight in (dash engine etc) or is it completely different?
    Moderator dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Completely different I think. I believe DA3 is Gen1, DA9 is Gen2.
    Member mooshie is a glorious beacon of light mooshie is a glorious beacon of light mooshie is a glorious beacon of light mooshie is a glorious beacon of light mooshie is a glorious beacon of light
    Jan 2004
    Adelaide Hills
    DA9T+DA6+DA5
    Correct ^
    Pretty much nothing is compatible with the DA9 although the DA1-3 chassis did run the ZC and d- series engines in various iterations which the second generation integras also had in the DA5, 7 etc. I remember seeing a member on here that was doing a B series conversion into his DA3 it is not bolt in but not too difficult either. I believe seats may swap over with minor modification and also wheels..
    DA9 LS w/JDM SiR B18C and a Garrett snail
    DA6 XSi Original JDM
    Wrecking red DA9(ask for parts!)
    B16 converted DA5 4 door
    Golf turbo diesel work car
    Feb 2011
    gympie QLD
    DA9,DA3,EG,DA9
    bugger, thanks anyway guys.. oh n were they released here??
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Yes they were released here. I love the look, nice cars. Bit old though...
    mooshie I think DA9 brakes (262mm rotor, caliper, pads etc) may be compatible with the EF8!
    Feb 2011
    gympie QLD
    DA9,DA3,EG,DA9
    ^ that they are, just sold the whole assemblies off my parts teg to a guy putting a h22 in his crx.
    Jan 2004
    Adelaide Hills
    DA9T+DA6+DA5
    Correct, all suspension from the DA5-9 is very similar to the EF and will basically bolt on.
    First gen DA integras use a torsion bar rear end and completely different front set up too. The mid 80s civics and crxs use similar setups but the integras had the 'best' of all of them, back in the day it was an easy upgrade for your civic/crx to swap all the mechanicals in.
  8. #8
    Feb 2011
    gympie QLD
    DA9,DA3,EG,DA9
    well looks like im getting a DA3! fella wanted $1500 (in rough condition and not running) i offered him $400. didnt hear back from him for nearly a month, then get a call yesterday 'you can come pick it up for $400...' WINNING!!
  9. #9
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Sweet
