+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
    Member euro1603 Knows a bit of info here and there
    Jul 2009
    melbourne eastsiderz
    07 CL9
    time to change brake pads?
    Checking the brake pads yesterday, the rear had about 50mm and the front about 80mm, i thought the fronts would have worn down quicker. My honda friend mechanic did worn me about the cl9 being notorious on the rear pads ? anyone agree ? also is it time to change the rear ? i generally go with the sound test, the brakes will tell you when to change.. what is the general thickness of new brake pads..
    -------Black CL9 07 ltd edt----------
    Ninja turtle aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute aaronng has a reputation beyond repute
    Chloe
    New pads have roughly 10mm of material.
    Stocky CL9 - 1:17.2
    Member Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding Fredoops has an exceptional understanding
    Oct 2010
    '03 Euro [CL9]
    Quote Originally Posted by euro1603 View Post
    Both Euro's AND accords have issues with rear pads wearing at a very fast rate.
    it's a known issue and there were recalls (and lawsuits) in the USA regarding this problem.
    my suggestion is to replace the rear pads with ceramic pads for longevity.
    03 CL9 5AT
    Comptech Icebox|Ralco RZ pulleys|K&N filter|DC Header|R/T 250cell Cat|Comptech RSB|Cusco TowerBar & Lower Strut Bar|Pivot Raizen|Magnefine ATF Filter|Redline D4 ATF|Redline 5w30
    Chloe
    From what I've seen, it comes from the hand brake cable being adjusted to be too tight. The Euro (CL9) is supposed to have 5-7 clicks, with 5 clicks actually being a bit too tight (I had 5 clicks and my rears were smoking after a drive on the freeway!). Best is to have 6 clicks.
    When you service your car at the dealership, they always adjust the cable to be tighter, and you can notice it after a drive where you have not used the brakes much but the rear rotors are too hot to touch because the pads are actually still in contact with the rotor eventhough the hand brake lever is all the way down.
    Same thing applies when one replaces the rear brake pads. They have to readjust the hand brake cable so that the additional pad thickness is compensated for.
    Stocky CL9 - 1:17.2
    I changed my rears to hawks, they are too abrasive and have eaten my rotors.
    Will go back to OEM next time.
    Oct 2010
    '03 Euro [CL9]
    Quote Originally Posted by power_of_dreams View Post
    Get bendix or supercheap posiquiet then.
    You really have no need to pay $100+ for oems
    03 CL9 5AT
    I guess it depends what rotors I get as well.
    Chloe
    Hawk HPS or the next one up is too aggressive. I used Hawk Ceramics, and they were more gentle than stock. The downside was that initial bite was weaker than stock. However total braking force felt much stronger than stock.
    Stocky CL9 - 1:17.2
    Oct 2010
    '03 Euro [CL9]
    it needs to warm up like all ceramics i think
    03 CL9 5AT
    Chloe
    It's not a true ceramic. It just has ceramic particles in it. Even when warmed up, the initial bite is not as good as OEM. I even tried overheating it and it never improved.
    Stocky CL9 - 1:17.2
    i think my rear brake pads got replaced around 50k km
    i got 88k km on the car now and still using the original front pads, quite surprised tbh, considering i have a lead foot
    ...read somewhere here that the oem pads are very good and its not recommended to go for cheap aftermarkets?
    also curious what are good aftermarket pads for the cl9?
    i gotta change my discs though, i get violent steering wheel shaking about 1/4 way into the brake peddle
    Chloe
    Stock Euro pads are shit...... When pressed against a hot rotor, they leave deposits on the rotor, giving you a feeling of brake shudder.
    Stocky CL9 - 1:17.2
