Results 1 to 6 of 6
    Mar 2008
    SYD-SG-JPN-MY
    parts list fpr b18c swap
    Honda eg gli non VTEC getting JDm 98 spec swap.
    I need the following parts -
    All the b18c plugs
    Obd1 to obd2 wiring harness
    Engine
    Gearbox
    Shift linkage
    Ecu
    Engine Mount s
    Drive shaft ??
    Am I missing anything ??
    Sep 2009
    Tas
    Civic EG8 B16A2
    If its a 2 post passenger side bracket, you do NOT need engine mounts, your EG ones will be fine. Unless they're cactus and you want new ones. You will need an ITR rear bracket however. Cheapest place I saw this was from weksos, but I can't find it now. Occasionally one pops up in the forums.
    I'd recommend getting an entire loom from an OBD 1 engine and swapping it over, rather than a conversion thingo.
    Yes, you need B series driveshafts.
    Are you keeping power steering and aircon? You will definitely run into issues getting the p/s hoses to connect up, and I think you will with the A/C as well.
    B series and D series radiator hoses are different sizes, I got caught out with this one. B series top hose is bigger, so it won't fit your D series rad. You will either need a new rad., or some sorta conversion hosey. (Note: The top hose is the one that connects to the thermostat.)
    Banned Array
    Jan 2012
    NondaRalliJuzz
    Quote Originally Posted by kcokla View Post
    All the b18c plugs
    Engine
    Gearbox
    Shift linkage
    Ecu
    Engine Mount s
    Drive shaft ??
    ye integ rear t bracket.. you can continue using your old eg mounts.. i would to use sikaflex on the old mounts to make them stable for the time being.. or upgrade..
    Account Disabled Array
    Aug 2004
    Garage
    All you need is B-series shaft. Its a straight forward conversion. You will need to do some wiring as well even with the conversion harness. We got shafts and conversion harness in stock
    Jan 2012
    Ek hatch b18c7
    Got rear bracket pm me
    Apr 2012
    WST SYD
    GOLDWING FTW
    I have everything besides the loom and convertor just have to donate you my hard wear for the b20 whilst my eg is decomissioned
    View Tag Cloud
