+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Hondata
    Member Hellomotog has made a significant amount of informative posts Hellomotog has made a significant amount of informative posts Hellomotog has made a significant amount of informative posts Hellomotog has made a significant amount of informative posts
    Jan 2012
    Sydney
    Ek hatch b18c7
    Hondata
    Hey guys wanna get a hondata for my b18c7 obd2 in a 99 civic.
    Currently running an ek4 wiring harness.
    Is it possible to use the p28 ecu? They go for about 500 on eBay delivered.
    Or should I buy a hondata unit and socket myself?
    When this is done who tunes these things?
    Are you saying it is $500 for a P28 ECU WITH Hondata already installed? If it is just $500 for the ECU, then that is too much. I bought a P72 ECU for $100 bucks which can be socketted and have the s300 chipped into it. I suggest you get S300 btw.
    Yes you can use P72,P30 or P28 which is basically ANY OBD1 ECU with VTEC and is 5 speed manual. You wll also need a OBD2a to OBD1 conversion harness.
    If you are conifdent with socketing and have the necessary tools, then go for it.
    As for tuning, this link has a list of tuners:
    http://www.ozhonda.com/forum/showthr...e-your-car-ECU
    Hope this helps.
    Any thread related PM's... PLEASE LINK ME THE THREAD YOUR MESSAGE IS IN RELATION TO... instead of me trying to guess and that way, i can understand your query better
    Thank you.
    Jan 2012
    Sydney
    Ek hatch b18c7
    Yes. Already socketed. So that will plug straight in?
    Moderator dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute dougie_504 has a reputation beyond repute
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Not straight in. Like infurNOS said you will need an OBD2 to OBD1 conversion harness. Then it will plug straight in.
    What modifications has your B18C7 got? Is it even worth getting the ECU + tuning (probably looking at a good $1500 here)?
    Quote Originally Posted by infurNOS View Post
    Hope this helps.
    Re the above link does anybody know of any other tuners in Sydney for Hondata? Does it make a difference who does it?
    Is croydon racing developments the only one left in Sydney?
    Jan 2012
    Sydney
    Ek hatch b18c7
    Got I/h/e
    Ordered skunk 2 cams and bigger throttle body. Bigger injectors and bigger fuel pump
    Probably need it.
    Quote Originally Posted by Hellomotog View Post
    Got I/h/e
    Probably need it.
    Cam gears aswell?
    Thank you.
  8. #8
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Supporting valvetrain?
  9. #9
    Jan 2012
    Sydney
    Ek hatch b18c7
    Yes. Do I need camgears
  10. #10
    You do not need them, but they are ideal as they allow you to shift the powerband, making your camshafts more effective.
    Thank you.
  11. #11
    a S300 is not a straight plug into a socketed ECU, the ECU needs to be setup for the S300 differently.
  12. #12
    Member rpm boy seems to know what they're on about rpm boy seems to know what they're on about
    Mar 2008
    under a bridge
    Jdm EG6
    ok wheres all the information on what ecu's and what sockets go with what? ive got an eg6 auto thats been converted to manual, what would be the easiest route to take with casings and sockets
    Quote Originally Posted by bennjamin View Post
    hmm id tap it. Even in mid air like that. Possibly with the pee pee flying out too.
    you guys remember squirtqueen.com ? I spent many a hr in computer studies in yr 10 looking that up.
+ Reply to Thread
