+ Reply to Thread
Results 1 to 6 of 6
    Member russell.94 Knows a bit of info here and there russell.94 Knows a bit of info here and there
    Sep 2012
    St Lucia, Brisbane
    Civic EG hatch
    eg LCA replacement - necessary for upgraded sway bar?
    Should/need I upgrade my rear lca's with my upcoming upgrade to a 22mm whiteline sway bar
    driving a 94 eg hatch
    Only if you don't have mounting points for the swaybar
    WP PB 1:26:9110
    If you have a honda eg si - then there are eyelits for a sway bar and you do not need to change the lower control ar,s
    Sep 2012
    St Lucia, Brisbane
    Civic EG hatch
    Quote Originally Posted by kcokla View Post
    I have a gli so I guess I'll be buying some new ones!
    WHen you buy them, think about your suspension set up too,
    some use a fork type and some an eyelet type
    From what i know, the eg/ek is the eyelet and if you get dc2r control arms or those styled ones your suspension is different too.
    Most suspension would come in both forms but something to be aware of.
    Sep 2012
    St Lucia, Brisbane
    Civic EG hatch
    yea dude I've got that sorted - I've already bought my shockies and theyre forked...
