Results 1 to 4 of 4
    Question B18B Burnt Exhaust Valve Problem
    I completed a compression test which showed that cylinders 1,3, and 4 had compression of 180psi and cylinder number 2 had a low compression reading of 150
    Upon disassembling and removing my b18b cylinder head, i noticed that 2 exhaust valves on one cylinder (number 2) were of an off white colour compared to all the other valves being a charcoal colour, and also the piston in this cylinder (number 2) is dry compared to the other pistons as show in the picture also.
ID:	23733Click image for larger version.
    I'm unsure what has caused this problem and what will need to be fixed/ replaced to fix the problem
    Could possibly be coolant burning to make piston that colour.
    Or could be really rich mixture?
    Oct 2006
    P1.5 460F/350R
    maybe your cyl 1-3-4 is showing wet compression test. so maybe 1-3-4 is leaking oil
    only 2 is dry compression, not leaking oil.
    yeahh the oil control rings were gummed up so that might have been part of the problem, i think it might be that the cylinder was running lean as the injectors where badly carboned up
    how will the car running rich cause this problem? as i also suspect the car might be running rich as its using alot of fuel
