Results 1 to 4 of 4
    Newcomer Array
    Feb 2013
    Melbourne
    Accord Euro CL9
    Bad wheel bearings? Accord euro
    Driving an 04 accord euro with 126,000km on it.
    Clicking sound coming from left passenger side wheel that increases in frequency as speed increases. No knocking or change when turning. Had 2 wheel alignments and car still pulls to the left. Also uneven wear on all tyres. Front passenger side worn on outside and driver side worn on inside.
    Any suggestions? Would be appreciated. Cheers
    Dec 2010
    Neverland
    Flying Carpet
    Driveshafts? , upper control arms and/or tie rods? The list goes on jack the car up and see if the wheels wiggle listen were its coming from. If it only happens when turning left its ur right driveshaft if it happens turning right it's ur left driveshaft . Goodluck I know how annoying suspension problems are..
    SingleCammerJammer
    A good mechanic can tell if it's wheel bearing. My mechanic can .
    I had mine front passenger side done last month or so. The symptom was noise like a scooter was running behind you, and yes of course it frequency change with speed.
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    Wheel bearing will be more like a humm rather than a knock.
    IT also wouldnt affect steering or wear issues.
    Sounds like a balljoint or bush problem.
    to see all of my build, checkout
