well here i was thinking everything was going so well. i have just about finished up the swap and then bam o2 sensor.
ok so currently i have the 4 wire set up as such;
o2 heater- pinned to A6 (getting power)
o2 sensor power- pinned to A25 (getting power)
o2 sensor ground-pinned to D22 (getting ground)
o2 signal- pinned to D14 (havent tested yet,no multimeter)
is there something obvious im missing here, the o2 is brand new and i just cant figure it out??? unless its faulty (which ill test with a multimeter when i get one)
Edit: im getting error code 1, well i think i am any way the CEL flicks off for less then a second then stays solid, but it only dose this once. maby code 0 i.e faulty ecu??
