what are the benefits of having 4.7 fd on a k24
As the title states above just wanting to know the benefits of having it on a mildly moded Accord euro. What other parts are needed to install this in a k24 box. Would it be worth it for me to add an lsd at the same time?
03 Accord Euro CL9, FlashPro, 06 TSX Intake Cam, 40* VTC, RBC IM, J35 TB, RDX Injectors, WeaponR header, 2.5 Catback Exhaust, Pivot Mega Raizin
Would be worth it IMO.
Only trade off is top speed (because we all do that..) and that you'd be cruising at a higher RPM on highways... (if that's what you're asking)
Also, as it's a relatively labour intensive job, i'd consider doing other thiings while the gearbox is off - perhaps flywheel/clutch if yours is aging?
S P A M | W O R K S
hehe.
PHC
4.7fd will massively help accelration when paired with the K24. The gearing in the euro box is already pretty long, and combined with the stock 4.3fd it really makes it quiet sluggish.
Alternatively, if you had the cash, you could always try find a gearbox from the EuroR, it should have the correct mounting points for the euro? I dunno. That way you will score the best of everything, massively shorter ratios/4.7fd/oem lsd. That will make a HUGE improvement in performance.
more push me for in car @ same rpm
Down side is more shifting if you're not that great at shifting then it'll be a disadvantage to consider...
Toda Racing AU | Shen * Speed Works | Jesse Streeter
Also what LSD will suit the tranny thats not to expensive?
You tracking or daily?
If you want less headache and less maintenance stick with the OEM Helical/Torsen [Forgot which one Honda's use]...
Its a daily with spirited driving. I've read some good things about wavetrac. Are they any good?
Wavetrac are an improved form of the Helical LSD you find in the Factory box =)
No experience with them no so can't comment..
either way with the LSD stick to a helical type for street, clutch type get too noisy. I've never had a wavetrac.
What you need for the mod:
4.7 FD
rear countershaft bearing (ball)
rear countershaft snap ring
shim*
and if you're doing LSD:
LSD
2x diff bearings
2x diff seals
This list IMO is the minimum. Some people might reuse the bearings but seriously why would you risk that, particularly when they've been pressed/pulled off. I'd also do the front countershaft bearing (needle) as a precaution. seals are also easy to replace while you're in there...
*Then it'd need to be shimmed, the one between 6th gear and the top bearing on the countershaft. You don't know what size you need until it's reassembled. Send me a PM if you need more help. Where are you?
4.7 FD
shim*
LSD
2x diff bearings
2x diff seals
Great post mate, need more guys like you!
