Hi CL9 owners,
Anyone here experience this issue where your car vibrates from the chassis up when accelerating under load?
Mine is having this issue and the most obvious is around the 95-100km, accelerating under load. But can also be felt light in other speeds when accelerating under load.
It's ok when just cruising.
This is apparently a know issue with some CL9 euros as I rang 2 dealership service centres and they both said it's the inner CV joint (not the outer one which goes clicks click-click-click from wear after the boot has torn). Both service centres said it is recommended to change both sides of the drive shaft assembly which includes the inner cv joint.
Thanks,
Vincent
EDIT: found this on whirlpool which discusses the same issue. http://forums.whirlpool.net.au/forum....cfm?t=2039162
