Page 6 of 6 FirstFirst ... 3456
Results 61 to 67 of 67
  1. #61
    Dec 2011
    egg
    loool
  2. #62
    Oct 2005
    Inala
    69' chevy
    Do you even lift?
  3. #63
    hows everything going?
  4. #64
    Jun 2006
    K20 DC2R
    hey op your problem sounds almost like mine i jus finished a b18c type r swap into my ek1. running ek4 loom and standard type r ecu.
    all is running well except i have now lost my tacho and possibly my temp gauge.
    Has any one had this issue before and have any idea of what it could be. I've read of something to do with a little blue wire?
  5. #65
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    There's a blue wire that goes from the tachometer to the cabin harness plug on the drivers side. There is also a little brown grounding wire that goes from the same plug back to the Ecu
  6. #66
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    Also it sounds you just took my post word for word....
  7. #67
    Jan 2013
    Brisbane, qld
    98 ek b18cr
    The problem was immobiliser.
    Someone had ripped the PCB chip off the ecu board rather than bypassing correctly.
    Has now been fixed and is waiting on a knock sensor before tracking it.
