Hey guys I've just done the cam belt and water pump on my Gsi and after I had a really bad misfire under load and found it had the wrong plugs so I've changed the plugs and that solved that issue it's almost running perfect now just has a rough idle/slightly mis firing. I took the throttle body off and cleaned it out but hasn't changed.
I'm thinking maybe I'm a tooth out now but I figure if it was a took out it would be running worse/not at all.
Any suggestions...
