Page 3 of 3 FirstFirst 123
Results 25 to 34 of 34
  1. #25
    Sweet yeah i think its okay aswell.
    I had already done 370kms with less than a quarter left on the gauge. So i put a full tank in again.
    It showed 29 litres on the petrol station pump meter when it stopped, so im assuming i still had about 11 litres left.
    EM1's are a 40L tank is this correct?
    But im still getting some black carbon on my rear bar
    just a tiny amount, when i swipe my finger on the rear bar, its just annoying thats all hahah.
    Maybe its a white car kind of problem LOL
    Thanks guys
  2. #26
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    No its not... I've owned 2 EM1's. I avged 350KM per tank was i was hitting Vtec every 2nd corner.
    Normally got approx 500KM per tank.
  3. #27
    Okay
    Highway driving aswell?
    When you fill up how many litres did it say on the pump meter?
    I was assuming i was okay because i still had 11 litres left and had already done 370kms?
  4. #28
    Nov 2009
    KSWAPPED STi -R
    Yeh Mixed of all sorts.
    I work 24 hours and drive all sorts of roads. Minimum 50KM per a day.
    From memory it was approx $50-$60 per tank which got me 500KM+ per tank if driven civil.
  5. #29
    Okay.
    I just checked my spark plugs and they are still fouled with carbon.
    Ill probably change my thermostat.
    Will scanners be able to see what is causing the problem?
  6. #30
    Where would you guys recommend to go?
    For a scan, to see if its running rich and what would most likely be causing the problem.
  7. #31
    Aug 2009
    Front yard
    4WD 89 Concerto
    I scan tool would not be able to pickup what's causing the problem unless you have a check engine light.
    Have you tried running some Subaru upper engine cleaner through the motor yet?
    OEM parts whore
  8. #32
    Also check valve clearance
  9. #33
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    How long you had the car, was it like that before ? when did the problem occurred?
    Try to use Fuel injectors cleaner.
  10. #34
    Nov 2009
    KSWAPPED STi -R
    I have a feeling Crayan maybe on the money with this one.
