Results 1 to 6 of 6
Thread: NA options
    Jan 2004
    Adelaide, SA
    EKD
    NA options
    Currently b16a2 stock pretty much has travelled a few kms 30x,xxx(car acquired around 295,xxx).. just want to know if it's worth throwing a few bits in to give it some umph...
    Option1:
    Ek9 cams, gears, im, tb, fpr, f.rails, injectors + eventual tune + itr gb?
    Option2
    b16a head fully built
    freshly machined
    ported & milled
    skunk2 internals
    -titanium retainers
    -valve springs
    - sprng base kit
    - skunk2 stage 2 pro series cams
    includes new headgasket and intake manifold
    Option3
    Nothing and drop a b18c5/7 later down the track
    Both options(1,2) can be had for similar price
    Do I need to worry about my stock bottom end with either option for its age
    Jul 2013
    Sydney
    Dc2r
    Seeing as you've hit 300000km, the age of the block may be a issue for option 1 and 2. If I were you I would save the coin for a healthy c7 package instead of using your b16 as the base.
    Jan 2004
    Adelaide, SA
    EKD
    What kind of costs to rebuild oem spec bottom end b16?
    Sep 2008
    Melbourne
    Kermit K20A
    Have you looked a doing an LS/VTEC conversion? This will net great midrange torque due to the long stroke while still maintaining good rpm.
    Also Skunk2 Pro2 cams on a stock compression B series is major overkill.
    Buddy Club Spec3, Rocket Motorsport M21x or M22x, Toda B are all good options for stock comp B series
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
    no replacement for displacement.
    i'd look at the b18 swap - especially if you can do the box as well
    Sep 2011
    forever waiting
    no weetek civic
    b20 vtec for sure
    build the block (even mild build would be brilliant)
    keep the head and you're laughing, maybe some head work if you're heaps keen.
    if you're gonna drop some coin, drop it in the right places.
    SSpamily
    hehe
