Results 1 to 5 of 5
    Aug 2008
    Melbourina
    Accord CP2 2010
    VTC actuator noise, 2.4L widebody 2010
    Well as the title says...VTC noise at cold start on colder mornings, only for a few seconds. Looking over the webz ...this appears to be an issue especially in colder climates but is starting to happen to mine. Vehicle done 120K.
    This appears to be a bit of an issue on these engines, need to replace VTC actuator. Well, that's going to cost! Time to pension it off? Pity everything else is still top notch.
    edit:
    oppps mods pls move to Accord forum not Euro...although this is pretty much the same engine it belongs in Accord forum.
    Oct 2010
    Melb
    '03 Euro [CL9]
    Service Bulletin
    © 2009 American Honda Motor Co., Inc. – All Rights Reserved ATB 41171-41384 (0904) 1 of 2
    CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment,
    and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume
    this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an
    authorized Honda automobile dealer.
    April 11, 2009
    09-010
    Applies To: See VEHICLES AFFECTED
    Engine Rattles at Cold Start-Up
    (Supersedes 09-010, dated February 11, 2009, to revise the information marked by the black bars)
    REVISION SUMMARY
    Under WARRANTY CLAIM INFORMATION, the
    Symptom Code has changed.
    SYMPTOM
    At cold start-up, the engine rattles loudly for about
    2 seconds.
    PROBABLE CAUSE
    The VTC (variable timing control) actuator is faulty.
    VEHICLES AFFECTED
    2008 Accord L4 2/4-Door – ALL
    2009 Accord L4 2-Door –
    From VIN 1HGCS1...9A000001 thru
    1HGCS1...9A004953
    2009 Accord L4 4-Door –
    From VIN 1HGCP2...9A000001 thru
    1HGCP2...9A029528
    From VIN JHMCP2...9C000001 thru
    JHMCP2...9C010096
    CORRECTIVE ACTION
    Replace the VTC actuator.
    PARTS INFORMATION
    VTC Actuator: P/N 14310-R44-A01, H/C 8665374
    VTC Oil Control Solenoid Valve O-Ring:
    P/N 15832-RAA-A01, H/C 7131873
    Chain Case O-Ring:
    P/N 91302-PNA-004, H/C 6753560
    REQUIRED MATERIALS
    Hondabond HT Liquid Silicone Gasket
    P/N 08718-0004, H/C 8263386
    (One tube repairs two vehicles.)
    In warranty: The normal warranty applies.
    Operation Number: 110153
    Flat Rate Time: 4.0 hours
    Failed Part: P/N 14310-R44-A01
    H/C 8665374
    Defect Code: 03214
    Symptom Code: 04201
    Template ID: 09-010A
    Out of warranty: Any repair performed after warranty
    expiration may be eligible for goodwill consideration by
    the District Parts and Service Manager or your Zone
    Office. You must request consideration, and get a
    decision, before starting work.
    DIAGNOSIS
    NOTE: If you’re reading this service bulletin on ISIS
    and your computer has sound, click on the picture to
    hear an example of the engine rattle.
    1. Allow the oil to drain from the VTC system by not
    starting the engine for at least 6 hours.
    2. Start the cold engine, and immediately listen for a
    loud rattle:
    Do you hear a loud rattle that lasts about
    2 seconds?
    Yes - Go to REPAIR
    2003 CL9 5AT *ECU REFLASHED*
    Aug 2008
    Melbourina
    Accord CP2 2010
    Thanks Freed
    yep it's VTC rattle all right. Worse on colder mornings some mornings its ok. Just put in some new HPR5 but I think its time to go for this one. CBF'd trying Honda for repair.
    Nov 2009
    The Guy Next Door, Lol.
    KSWAPPED STi -R
    Might as well do the 200k service now and call it a day.
    Aug 2008
    Melbourina
    Accord CP2 2010
    Ok the outcome
    Went to Honda and Toyota looking to downsize to a new car. Honda have Civic Vti-S for $23,990 drive away (Ringwood). Couldn't refuse...much better than Toyota, so changeover is $11,500. The Toyota was ok but felt noisy in the cabin and was way more expensive. We had a 2008 civic so we knew what they are like...save for they now have features and more that were extras on our old civic vti-L.
    So pretty much all done bar the signing. I'll miss the 2.4L but meh...the civic isn't all that bad!
