Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
    Feb 2011
    Geelong
    EG4 B18CR
    guage only show you when your car running risk but don't need to if you don't like this
    Aug 2009
    Front yard
    4WD 89 Concerto
    Quote Originally Posted by infurNOS View Post
    TBH I dont even think I need a guage. As long as it is connected to the s300 and logging the wideband values in SManager ill be happy
    Pretty sure you need the gauge as that's the controller
    http://www.ozhonda.com/forum/showthr...=1#post3839254
    Have a read of that thread as well
    OEM parts whore
    Jan 2010
    ACT
    DC2
    If you aren't getting the car tuned you can install it as a secondary O2 simply to feed data to the gauge. If you are getting the car tuned then definitely replace the narrowband with the wideband, wire it into the gauge/controller AND the Hondata unit/ECU. It's only one wire to the ECU normally, and it should just go to the pin that the stock O2 signal wire runs to. It'd be a waste not to get proper use out of it or see the benefits of running a wideband in the first place.
    -ZAMMIN-
    - Integra-GSi 19/11/2015
  4. #16
    I am getting it tuned. My tuner has wideband but it is only tailpipe sniffer. Is it worth spending 200+ for a little bit more accuracy or will the tailpipe sniffer suffice?
    EG
  5. #17
    Dec 2008
    835 Beaufort St
    hondie 2000
    Strongyl recommend getting it if tuning
    hehe.
    PHC
