Agree with posting the printout. Here are the stock specs for CL9 (2003-2007) from the factory:
Front
Left & right Toe: 0 mm (+-1.0 mm) on each side
Left & right Camber: 0 º (+- 45')
Rear
Left & right Toe: 1 mm (+-1.0 mm) on each side
Left & right Camber: -1.0 º (+- 30')
Note that the front toe is actually 0mm. Standard practice by many tyre shops is to dial in -2mm total toe in (-1mm on each side) to increase straight line stability. This is not required for the Euro but many tyre shops still do it. The toe in will increase tyre wear on the front outside tyres when you are turning in.
