Results 1 to 5 of 5
    Apr 2015
    Syd West
    S2000
    Unhappy Help with cold start engine problem
    Hey guys, I've just recently bought an Ap1 Honda S2000 and I must've only test driven it while the engine was hot. Once bought, the next day I started up the car and I noticed the engine was stuttering or consistently changing rpm while warming up. It almost sounds like the car will stall, but it hasn't yet. When the car is warmed up, idling at traffic lights/stops everything is OK.
    Is this a common problem? And is there anyone out here that can advise what to do? If not directly advise a mechanic what to look for?
    Please view below video of current problem.
    https://youtu.be/9awk0cpF4C0
    If it helps, I'm also located in Sydney.
    Thanks all.
    Oct 2011
    16 Wilkins St E Annerley
    Toyota Soarer
    When starting the car, try pushing the button in harder
    On a serious note, could be coil pack issue
    Apr 2015
    Syd West
    S2000
    Really? I'll try that next time, but I usually press the button just to get the car started.. any longer I feel like I'm going to cause a problem.
    How and where would I be able to obtain if that is the problem?
    Oct 2011
    Toyota Soarer
    It's not the button, I was joking.
    Coil packs can get from Honda
    definitely sounds like a coil pack/spark plug issue
