Hi guys,
My 05 Euro has a noise coming from the power steering pump. Check out the video
here. Sorry it's so shaky, but I was filming and turning the wheel. In the video, I turn the wheel and you can hear the noise slightly, then I go to full lock and you can hear it a lot more. I go back and forth on full lock a few times, then turn the wheels full lock the other way towards the end of the video.
This was filmed when the car is cold, and when the car is cold it's more obvious, but I think this is because the revs are up. If the car is warm, and you rev and turn the wheel, you can hear it as well.
My mechanic suggested a full flush of the power steering system, and I got a quote from Honda for $130 which involves them disconnecting one or both ends of the steering rack while the car is running, and flushing fluid through it.
Apart from the noise, the steering seems fine, but I was just after some thoughts.
Cheers,
Adam
