Hi Everyone
Need your advice on the following if you can: Gearbox is crunching in several of the gears (double clutching seems to help with clutch flat to the floor and no noticeable slip).
Changed fluids with little difference and may be up for a recon gearbox?
1) Any thoughts about the gearbox?
2) Should I replace the clutch at the same time if I go ahead with another gearbox and other parts
3) Any recommendations on where to get parts from (I am in WA)
I have started to read some forums and have picked up snippets of information but I am a noob when it comes to cars!
Thanks in advance.
Reth
