Results 1 to 1 of 1
    How to install VAREX Smart Box
    The Smart Box controller module is designed in such a sleek and robust form that it can be easily tucked away in various tight spots inside the cabin.
    OBDii Data Cable and Varex Muffler Motor Power Cable can be concealed inside the suitable inner panels, which makes the whole set-up hidden away and not being intrusive.
    The module needs to be connected to the following devices
    • 12V socket via power cable
    • VAREX Exhaust Valve Motor via power cable
    • Vehicle’s OBDII Port via ODBII cable.
    • Smart phone * via Bluetooth® after installation
    Steps:
    • Connect the OBDII cable to the OBDII Port in the vehicle by plugging the dongle to the port.
    • Connect the RJ12 (Square adaptor) to the Smart Box Control Module.
    • Conceal the cable inside suitable panels if possible.
    • Connect the power cable to the Smart Box Control Module.
    • Conceal the cable inside suitable panels or carpet if possible.
    • Connect the power cable to the VAREX muffler motor.
    • Conceal the power cable inside suitable panels or carpet if possible.
    • Connect the External GPS Antenna.
    • Conceal the Externa GPS Antenna cable along the pillar trim, attach the antenna receiver on the surface of the windscreen using double-sided sticker.
    HOW TO USE IT?
    Start the engine.
    Open the Smart Phone App.
    Waiting for the Smart-Phone App to connect to the Smart Box Control Module.
    Once the connection is established, start using the App to operate or make change to the setting of the Varex Exhaust.
    Once the setting is completed, the App can be closed or left open according to the user's preference.
    By pressing on the reset button using a small pin it can move the exhaust valve to close and open position in sequence.
    By holding the reset button using a small pin for longer than 10 second until the blue LED indicator flash quickly, it will reset to the factory default settings.
    *App currently only available on Apple App Store. Coming soon on Google Play.
    Contact your local XFORCE authorised dealer today to purchase yours: www.xforce.com.au/where-to-buy
    For more information on the VAREX Smart Box, visit http://www.xforce.com.au/varex-smart-box
