Results 1 to 1 of 1
    Motul - Gear 300 LS 75W-90 gearbox & differential fluid
    Much like your engine, your gearbox also needs regular fluid changes to keep it performing in top-notch condition. A 100 per cent synthetic ester-based lubricant, Motul Gear 300 LS 75W90 has been designed specifically for high performance and racing applications.
    Motul Gear 300 LS 75W90 can be used in everything from synchronised or non-synchronised gearboxes, gearbox/differential, transfer gearboxes and hypoid differentials with limited slip systems operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speeds.
    Developed to withstand extreme pressures, Motul Gear 300 LS provides efficient anti-wear protection, better resistance at high temperature and an overall longer service life. It also contains a special friction modifier that works to help prevent noisy or dragging in limited slip differentials. With a high level of lubricating power, friction and wear is decreased and you can expect smoother, easier gear shifting even in colder conditions. Motul Gear 300 LS is suitable for any type of seal and any type of material used in gearbox and limited slip differential design.
    Motul Gear 300 LS is suitable for use in cars requiring 75W 90 gearbox or differential fluid that utilise limited slip differentials either integrated or non-integrated in the gearbox. It is also suitable for use across a wide range of motorsport applications from track to rally.
    WHERE TO BUY: Motul Australia – Dealer Locator
    Stay connected with
    Motul Australia – Cars Facebook Page
    Motul Australia Website
    Motul on YouTube
    We’re here to help!
    Can’t find an authorised reseller near you? Any questions on queries? Let the Motul team know. Send us a PM!
    If you have any questions about any of our products please feel free to get in contact with us.
