Hi all.
Bit of background - I blew up my engine. Cooked it ages ago, then finally the head-gasket went. Lots of white smoke from exhaust, but the electrics were OK.
ECU is an S300 Hondata piggyback
While installing my replacement B18C Type R long-block, I managed to swap the TPS plug & the other one a few cm away.... So the sensor that was expecting 5v got 12v.
The replacement engine doesn't start.
Fuel is OK - New-ish fuel, good filter, the external pump runs as normal & I get a return to the tank from the fuel rail.
I tested the sensors with a multi-meter, & they seem OK.
I've got spark, but the injectors don't fire. I removed the fuel rail from the engine while leaving it connected to the loom & got someone to turn over the car. Nothing happens. I haven't checked if I have power to the injectors, but both power & signal wires come from the ECU, so I'm getting convinced that I've burnt out something in the ecu.
Is there any another tests I can do before I raid the piggy bank & order a new P28 ecu chipped for the Hondata?
