Results 1 to 3 of 3
    Spoon twin block 4 pot calipers
    Hi guys. Looking to fit spoon 4 pot brakes on my eg4, currently running dc2 262mm front rotors and calipers and 15" enkei big end rodders on my rig.
    I know from research that I need to have a 300mm brake rotor but I'm not 100% sure on what inside diameter of my wheel I'll need to clear this set up. I'm also not sure as to which calipers will be a direct bolt up onto the current hubs as I'm still running the standard stud pattern, no 5 stud conversion.
    Any information regarding the best way to measure the internal diameter of the wheel most accurately would be amazing!
    Any information (and or links) regarding which calipers I need to purchase for direct bolt on application would also be amazing as I'm not going to fork out all that cash until I'm 100% sure it will work!
    Thanks guys
    Sent from my SM-G960F using Tapatalk
    Feb 2009
    victoria
    grey 94' EGG
    http://honda-eg6.blogspot.com/2012/0...45020.html?m=1
    Hopefully answer some of your questions
    Quote Originally Posted by junoki View Post
    Champion!! Thanks heaps
