i heard its a few hour job if you know what you are doing, also you should get the torque setting for the bolts. I heard if its not tight enough, things go wrong, and if its to tight.. things go wrong.
u want to torque it up right, u also need to replace all seals, cause once u remove the I.M it wont be a tight one anymore. U have to know how to remove injectors as well. The seals there may be reusable. But I reckon u get new ones. Im not sure if Charlie will use the old ones or new ones. There are also instant sealants, similar to locktite but not. If you know what your doing then yeh around 3 hrs.. if not.. it will take longer and you might end up screwing it up instead.
