CRVTEC if its done properly maybe - but seeing as it isn't standard (ie you spend alot on the parts for it) you could put as much into the B18C and be comperable.
Ok a B18c Type-R engine makes around 95-102kw ATW if you do a B20B VTEC engine with Type-R cams and intake it will make 109+kw without trying.These figures are from our last dyno day hope this helps.
Regards Dyno Dave
Buddyclub Australia Member of Master Of Vtec Group
Regards Dyno Dave
Dave,
I know you can't really compare dyno readings, but on my EK4 with 2 inch cat back exhaust, and CAI, it did 95kw (from memory) on the CRD dyno.
can you guys tell me what these guys have left out. if you do it the way they did it it should be no more than a $100 if you already have the b20 block and head and you do it yourself
