Results 1 to 1 of 1
    Oct 2003
    '88 Civic GL
    Suspension / Handling Fequently Asked Questions
    This thread is for the commonly asked questions regarding suspension and handling. This will be updated regularly, and if you think anything should be included please PM me and let me know.
    Wheel and Tyre Bible
    A guide to everything to do with tyres & wheels
    Tyre Recommendation thread
    A guide to what OZHonda users thought of various tyres and what they reccomend
    Springs, shocks and lowering
    The effect that lowering your car will have and how the springs work with the shocks
    Suspension Technical Definitions
    Goes through what each suspension component does and what the terms mean
    Swaybar / Camber fitting
    How to fit swaybar's and camber kits
    Swaybars function/explanation
    A guide to how swaybar's work and how they help you
    Wheel Definitions
    A details on everything to do with wheels (PCD, offset, size, etc..)
    What is offset?
    A definition of what offset is and how it works
    Honda's with / without swaybars
    A listing of which models come with front/rear swaybars and their sizes
    Tyre size / rim calculator
    This tool helps calculate and compare your current stock rims/tyre dimensions compared to others.
    Stiffer Chasis
    Adding bars to increase chasis rigidity
    DC2 Vti-R stock suspension upgrade recommendations
    Integra VTI-R DC2 suspension guide
    Subframe/swaybar 101 EK/EM/EJ
    Summary of what subframe re-inforcements are out there and why they are needed.
    Alloy lug nut dangers
    Dangers of using aftermarket wheel nuts with the wrong type of mating face.
    Check out my ED Civic progress here: http://edcivicracecar.blogspot.com.au/
