Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958 subs facing boot or cabin?
hey ive got 2 x 12" kicker COMP subs, usually i have them setup facing the boot, but when i re-arranged my amp i had to face them inside the cabin because of lack of wiring. now i found that at the same level facing inside the cabin it starts to distort for some reason, it maybe something rattling but i took everything out and it still sounds the same, so im not sure about that.
would you feel the bass more from the outside if the subs were facing the cabin or the boot?
i havent tuned the audio setup atm, im gonna get my audio mate to come see what he can do.
didnt know bass can bounce back and forth inside a car
Stoosh, facing towards the boot will give you some cabin gain and a longer wave length, which isnt a bad thing, but you really want the subs going bang at the same time the front mids go bang with the bass note, facing them backwards will delay the subs from the front. having them facing forwards and if you have a deck with time alignment you are able to delay the front using the time alignment to allow the sub to catch up in a sense and the whole bass experience becomes more in time and the way it should be.
if you arent sure shoot me a PM and i can explain a bit more.
Albert Einstein Two things are infinite: the universe & human stupidity; I'm not sure about the universe.
Put your location in your profile, makes referring help easier!
^^What he said. The only time I face them back is for competitions. It allows the waves to hit the mic point just right and the pressure seems better too. Don't know why as I am not a physics major or anything it just seems to work that way. We also do it in most cars because it's done for cosmetic reasons. If the customer is spending money we can get hardware that can delay the signal or change it in a way that it wont effect the mids/highs also can be done with a good tune. Everything to do with a car seems to work best with a good tune! I guess face them what ever way is most convenient for you and then listen to it. If you don't like it move the box around. Unless you want to spend time researching and testing configurations just put it in and take a listen, your ears will be the true testers.
The aiming of subwoofers has been quite a topic of speculation for years now in car audio. Through experimenting many people have found that their subwoofers sound much better when aimed backwards. Many people realise that there seems to be much more bass with the boot open than with the boot closed. We've heard a great deal of strange and utterly incorrect theories to explain this phenomenon.
The main reason this phenomenon occurs is all about sound waves (direct and reflected) and more importantly the cancellation of these waves. The diagrams below assist in showing the sine waves and their phase relationships between the direct sound wave entering the car and the reflected wave that hits the back of the boot and reflects forward. Since the reflection is bounced into the listening area one can treat them much the same as having two sources.
In the above picture the vertical black line at the left of the picture is the boot rear panel (the beaver panel the tail lights are mounted on). This picture is an illustration of what happens when sound comes out of the front side of the subwoofer enclosure. Sound travels forward into the car (the purple wave) and also backwards to reflect off of the back of the boot (the red wave). Both the direct wave and reflected wave get to the listener but they are slightly out of phase causing a variable amount of cancellation in the listening area. At this stage if you opened the boot the reflected wave would disappear and not reflect back into the car, thus resulting in no cancellation.
In the picture above picture the speaker box has been aimed at the boot instead of the rear seat and you can clearly see the direct and reflected waves are not nearly as much out of phase as in the first example. This resulting in much better bass reproduction.
This picture above represents the subwoofer enclosure being moved to the rear of the trunk with the subwoofer aiming forward. The waves are a little closer to being in phase with each other.
In this picture (above) we're aiming the rear mounted subwoofer enclosure at the rear so the direct and reflected wave are very close to being in perfect phase from the start and hence they reinforcing each other quite well.
Note; these pictures are simulated using a 60Hz note with the rear of the box mounted approximately 3 feet from the back of the boot. Keep in mind we're only discussing the direct and rear reflected sound in an effort to try to simplify this. The reflecting sound waves in a car are much more complex than these drawings indicate but we must start simple before getting too carried away. For example, remember that placing the subwoofer cone face too close to any panel can load it (resulting in a similar effect to that achieved by a bandpass enclosure) but we'll worry about that another day. This explanation should be a nice foundation for those of you who wish to study this phenomenon further. One other thing we should mention is that before people comment that this cannot be true because the interior of cars being small in relation to bass wavelengths, the full wavelength does not have to completely develop to be in or out of phase with its own reflected sound. The pictures above are showing a 60Hz wavelength and the bounce distance to reflect back out of phase a complete 180 degrees is just over 4 foot. At higher frequencies the distance is less (120Hz is 2.3ft for example). Remember, the key is to experiment and see what works best for you and your vehicle.
i've got a EG hatch, i face it towards the boot and im running the sub off phase and it sounds alot better than running in phase facing the front. also regarding outside the car mine sound 2x as loud from the front of the car compared to if u stand at the bak of the car...
i think its a good setup for hatchbaks.
Originally Posted by riceball
ballers like barefootbonzai can afford to spend money on his car and save for a future...
Can I just say also that this WYSISYG editor is not the easiest to use.
I'm sorry. Try Termpro or Bassbox Pro. Both are good to use. Termpro is a little more expensive but if you need a RTA it makes the package a great deal.
[QUOTE=mj3610]i've got a EG hatch, i face it towards the boot and im running the sub off phase and it sounds alot better than running in phase facing the front.QUOTE]
I find the exact opposite.
Facing back is way too boomy.
^^^ are u running it off phase? i found it abit weird when i faced it towards the bak it didnt sound that good but when i ran it off phase it sounded alot better
Dude, the WYSIWYG (What You See Is What You Get) system is the type of user interface used with this forum software. Nothing to do with what we're talking about.
