Page 3 of 4 FirstFirst 1234 LastLast
Results 25 to 36 of 44
  1. #25
    Jan 2004
    Sydney
    EK (sold!)
    Quote Originally Posted by connorling View Post
    how come when i undo all the bolts and nuts around the sump, toward the clutch, this metal thing stop the sump from coming off.
    what to do?????
    ugent!!!!thanks
    Remove the metal thing.
  2. #26
    Ozhonda Supporter Array
    Jul 2004
    Brisbane
    MV Agusta F4
    what to do?????
    ugent!!!!thanks
    Quote Originally Posted by imashy14u View Post
    ^^^ exactly, then you can access more sump nuts & bolts. Easy.
    Deano.
  3. #27
    Feb 2011
    Melbourne
    92 B18 eg Civic
    Sorry to bump an old thread but i've done this recently on my b18c7 with oil cooler & relocation kit. The spring initially either had no washers (or I lost the washer when the spring came out). I added 3 washers and checked my oil is topped up correctly. My vtec still cuts out between 7-max rpm. Should I add an extra washer? I can also shorten the lines by maybe 50mm maximum if that would help.
    Contemplating getting an oil pressure gauge to check first because taking the sump off is harder than I thought it would be
  4. #28
    Jul 2004
    Brisbane
    MV Agusta F4
    It does not have any washers initially. You might have another problem. 3 washers are plenty.
    Deano.
  5. #29
    Feb 2011
    Melbourne
    92 B18 eg Civic
    Hmmm. Sorry to get off topic now but any idea what could cause those vtec symptoms?
  6. #30
    Green block gangster Array
    May 2004
    twin GX160's
    do you have a dent in your sump ?
  7. #31
    Feb 2011
    Melbourne
    92 B18 eg Civic
    Actually I do. But it has always been there and vtec was always fine. Could the oil pressure change+dint cause problems?
  8. #32
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    Is your solenoid alright, no leaking or blown gaskets? They can go 'pop' in an instant.
  9. #33
    Feb 2011
    Melbourne
    92 B18 eg Civic
    My oil cooler line blew the other day, caused near instant/sudden oil pressure drop. Could that cause the solenoid to pop? Is there any way to test it?
  10. #34
    Jan 2008
    John St, Cabramatta
    DC5R
    Can u do same for k series?
  11. #35
    Aug 2010
    Melbourne
    Integra GSI
    i might actually try this on my GSI haha
    ill give it a go and see how it goes. feel like doing something different to it
  12. #36
    Oct 2009
    hehe
    hehe
    Bump for great thread, goot info.
