I remembered someone saying upgrading your rear swaybar anything bigger than 14mm should have some sort of bracing, if that's true then 13mm makes sense.
jing. anyhting above 22mm would need bracing. such as whiteline reinforcement kits. beaks. home made or ASR Brace for the wealthy
edit: okay.. theres a prioblem. i just grabbed my standard sway to measure it. with one eye closed, it reads 16mm on the ruler, with both eyes open, it reads 13mm. gonna go measure the circumference, and do some calculations. brb
