I have browsed through the Civic and noob threads in regards to this question with no luck. The things I would like to know are what parts/model do I need for the EFI conversion? I'm guessing that a GLI fuel tank will be needed, does the GLI tank run a internal or external fuel pump? Can I use the GL's Carby fuel lines on the GLI's tank or do I also have to use the GLI's lines. I'm only after fuel supply info as I plan to bolt in a EFI H22A engine. Lastly what Interal/external fuel pump is recommended for the H22A swap? Cheers.......
