Hey guys,
My dad broke the coolant bleeder bolt/valve by overtightening
I was just wondering what the thing it bolts into is called so I can ring around for it.
Refer to pic.
as far as i can see from the service manual this part is not actually named.
i think your best bet would be to ring a dealer (even if you dont intend to actually buy the part from them) and say that youre after the part of the cooling system that has the drain bolt, and attaches at one end to the block, and to the upper radiator hose at the other.
i think they would be very likely to understand what you mean
also - the likely cause of the break isnt so much over tightening, as tightening with poor technique - too much sideways pressure, rather than in the direction in which the socket is meant to be turning.
i made a similar mistake installing an oil pressure gauge.
radiator hose upper connection to cylinder head
or.
coolant bleed valve housing on cylinder head.
is what i would call it, and so would alot of work shops really.
