Results 1 to 10 of 10
    Jan 2007
    QLD
    B20 Del Sol
    Apexi VAFC II or AFC NEO??
    Which one is better?
    Feb 2006
    Melbourne
    Civic EG4 B16A
    id like to know 2...
    also with this... can you have it with a aftermarket ecu???
    me noob...
    Got an old Videogame console, handheld, games and accessories. PM me! I want them
    afc neo is superceeds the vafc a bit more tuneability..
    you can fit it with aftermarket ecu but if the ecu is fully tuneable why would you ??
    Jun 2006
    WA
    EG+CL9
    whats better... tune stock ecu with vafcII
    or tunable aftermarket ecu?
    value for money and power?
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Quote Originally Posted by TheSaint View Post
    VAFCII cannot alter ignition timing. It can only alter fuel maps and vtec point.
    Aftermarket ECU or even a product like the S100 can alter ignition timing as well.
    Stocky CL9 - 1:17.2
    Jan 2007
    QLD
    B20 Del Sol
    So The NEO is better - as is a bit MORE tunable? - YES???
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Quote Originally Posted by Honda_CRX View Post
    No, Neo is the same as VAFCII, but it supposedly cannot alter the VTEC point for i-VTEC engines. But the Neo has a graphical interface, while the VAFCII has just text. So in terms of tunability, the Neo is worse than VAFCII for i-VTEC engines, but are the same for your CRX.
    Stocky CL9 - 1:17.2
  8. #8
    Array
    Aug 2003
    Unit 5/15 Sefton Rd, Thor
    08 Red CU2 Euro
    IMO, for most Vtec Honda's - the VAFC II
    Fuel & Vtec are directly adjustable.
    The tuner needs to be aware that timing is also affected as the MAP senor output is the tuning key.
    TODA Performance Australia Pty Ltd
    TODA Racing - FIGHTEX - MFactory - HALTECH - EXEDY
    Race engines, Dyno tuning, Licenced workshop, Parts.
    P:0401869524 email: toda@todaracing.com.au
  9. #9
    but doesnt afc neo have more tuning capability then vafc 2 ??
    afc has 16 point fuel correction whereas the vafc2 only has 12 ...
    but to me i dont know what that means :P
  10. #10
    Jan 2007
    QLD
    B20 Del Sol
    Thanks for the input fellas.
