Hi
Are they side mount or bottom mount.
Mine were bottom mount so i mixed my jdm rails with Aus spec rails, using the ones without the L bracket, (the flat ones) the jdm rails and Aus spec rails have the L brackets on the opposite sides.
Remove L brackets in order to bolt on steel plate.
Then get some 5mm steel plate and cut 4 rectangle shapes depending on the dimensions of your seat.
Bolt the steel plate to the rail, then bolt plate onto the seat.
I was lucky didnt have to drill or cut, so see if you can make a steel adapter without needing to alter your stock rails.
If the seats fit in between the rails you can maybe leave the the L brackets and make some sort of L bracket adapter.
There was alot more involved like aligning the seats etc, but try and use your original rails engineers like that.
Id like to see other pics of DA's and how low the aftermarket seats are sitting.
i got mine lower than standard but couldnt go any lower seats wouldnt fit in between the rails so they had to go on top.
