I know this may fall on deaf ears as most members probably don't even check here or read sticky's.
But out of genuine concern for members when i post on any forum, If i have a thread on a problem and it has been solved...
I add to either the original post or the post with the solution the following:
Search Keywords: ICM, Ignition Control Module, Ignitor, Igniter, high rpm misfire, no start, no spark, stall, stalling, engine cut out, tacho signal, rpm, over revving
This way every possible way of describing an issue can be covered and therefore makes searching easier... especially when non-normal issues arise and where part numbers are involved.
I duno just a suggestion for everyone to maybe make a habit of?
