Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: wat to look for
    wat to look for
    i want to know what to look for when buying a second hand eg preferably where rust starts and other need to know things
    May 2004
    East Lindfield
    Honda
    check tyres for wear could haggle abit if anything need replacing soon
    check brakes for wear
    check for rust
    check that panels line up and colour for previous accidents
    check engine bay for leaks and cv boots
    test air con if its working and cold
    check timing belts
    check for service history
    check all fluid levels are level and not empty
    check if the car blows smoke
    check all lights are working
    check windows and doors shut properly
    check for spare tire and tools
    road test the car take every turn/hill/ or highway to see if it struggles in any way
    see if the gear change is smooth
    check clutch wear
    check hand brake if recently adjusted it should only click around 5-7times i think
    check for noise when turning doing full circle
    test the brakes
    thats all i could think of =]
    Sep 2006
    Shibuya
    Corolla type R / CRV
    check seats and carpets for wear, if the odometer reading is relatively low you would assume wear on these 2 things would reflect the kilometres
    Oct 2006
    Brisvegas
    DC2R
    sounds kinda obvious but
    check the lights , blinkers, A/C, Fan
    _________________
    What you mean N/A !!!!
    thanx all its all preety simple stuff rely
    is there any thing else that goes wrong with civics ??
    that is a worry?
    Apr 2007
    south-west sydney
    push bike
    EMO! lol how u goin little fella...
    its petes mate from dalmar smash lol
    the guy with the prelude lol
    lol @ emo lol
    shooting cac
    Sep 2007
    Syd
    Stealth
    Thumbs up
    Quote Originally Posted by he-tec View Post
    check for rust
    check timing belts
    check clutch wear
    test the brakes
    what he said LOL!
  8. #8
    Jun 2007
    Melbourne
    2001 DC2R
    Brake hard and accelerate hard without holding the wheel too tightly to see if it veers.
    My order's simple... a sh*#load of dim sims and a bucket of soya sauce.
    Low cost mod: Filled my car with helium balloons. Power to weight biaaaaatch!
  9. #9
    - gearbox; runs smoothly. No crunching between 1-2 and 2-3
    - radio antenna clicking when going down
    - water in boot
    - power windows rattling
    - CV joints; cracked or not (check inside wheels and suspension to look for grease spills
    - Check oil
    - Check around actual engine to see for any oil leaks
    - Check under car (if you can get under it) to look at oil sump to see if its leaking
    - Engine mounts; this is something you can feel when driving. If you are a little *rough* when driving and accelerating in first and then throttle off, if it clunks, then the engine mounts are bust.
    - interior should be quite clean and in good condition. Check under the floor mats to see the driver wear (from shoes etc)
    - CHECK LOG BOOKS
    - Radiator fluid (if its been serviced regularly and not just stamped from a friend – the fluids should be quite clean)
    - Air con full blast while you are driving so you know the aircon is working (it should be quite cold)
    - Water in headlights/tail lights
    Also in the log books you want to see that the major services were done at a reputable mechanic and major things like timing belt, air filter, all fluids (engine, brake, gear box) were changed for new ones, and then also that major things were checked, for example cv joints, engine mounts, bushings etc.
    Sorry if there is any repeats.. gl with it!
  10. #10
    Quote Originally Posted by est1989 View Post
    lol @ emo lol
    hey i don't work there now !! LOL
  11. #11
    Smile
    Quote Originally Posted by mattc View Post
    - water in boot
    - Check oil
    - CHECK LOG BOOKS
    na it's good stuff thanx all and i'll do what i have to
  12. #12
    midori Array
    Sep 2005
    south west!
    EK4
    emo u dumb shit u work at a panel beater. u should know
    lol
