Hey!! Is there any difference in the look of a b16a2 to a b18c7 Apart from the red rocker cover on the b18c7??
size wise i think the b18 is slightly taller, you'd find the engine number stamped on the block too(either b16 or b18)
Sydney Garage Cleanout! B series valve cover, hardrace compensator arms and more.
intake manifold bigger leads
BIG JDM TYPE R PARTS FOR SALEhttp://www.ozhonda.com/forum/showthread.php?t=117546
if your trying to work out what engine you or one of your friends has or something,it is easy to see the engine number stamped on the front of the block near where the gearbox connects
CHEAPEST PRO DIY
is there a type-r version of the b16 like the b18c7 is the type-r b18?
---------------------------- D15b Turbo EG Sedan Build + CL9 Lux N/A Build http://www.ozhonda.com/forum/showthread.php?t=127680
Yes. That is the "b16b" - found only in the EK9 / civic type R.
Thanks 4 ur help guys iv worked it out
