Results 1 to 3 of 3
    Jul 2007
    Brisbane
    4 banger
    P28 ECU wires help!
    i've been doing some searching over the net and i have finally found a decent picture the shows a pin out diagram similar to a p28.
    i need to find the following:
    -IG power
    -Ground
    -RPM signal
    -Throttle signal
    -Vtec solenoid
    -Vtec oil pressure switch
    so far i am able to find the following (but can anyone fill in the rest and confirm that theses are right)
    -IG power (A25)
    -Ground (A23)
    -RPM signal
    -Throttle signal
    -Vtec solenoid (A4)
    -Vtec oil pressure switch (D6)
    can anyone confirm this and help me find the pinouts for RPM signal and throttle signal
    ohh herrow im jdm
    Green block gangster Array
    May 2004
    twin GX160's
    RPM = ICM A21 and A22 TPS = D11
    Jul 2007
    Brisbane
    4 banger
    cheers, i got it. =) thanks
    ohh herrow im jdm
