I'm communicating with the seller via email. He doesn't know the bolt pattern either so I got him to measure that up to see if it is at least the right bolt pattern first. Quick google search suggests skyline uses 114.3mm, which is a good start. Then because the rays stickers is pretty much destroyed, I might have to do a test fit.
they should be real geniune te37's it says on the label with the date made. and the first pic doesnt look right maybe because the tyre size it big and the rims look abit smaller ?
believe me.. even if you have tyres on it.. pick it up and you will see if its genuine or not. on the inside of the wheel, where the holes for the studs are, it will have embossed RAYS ENG
12.949 @ 107.71mph 2.063 60ft on Advan AD08 EKK20A 142.9kw on 98ron
