Does anyone know if this is a good Turbo? It would be for my d16y4 96EK1 Civic Sedan.It looks small but he said it was the equivalent to a T3 Turbo...
Cheers!
i've got a write-up of a b16 running this in the US. Theirs came a differnt car can't rem which. It was apparently fine. It had the smaller rear but was maxed out at like 16PSI.
The only issue you have is the manifold setup.
I'd stick to a garret or mitsubishi as they have better quality turbos and better support. Also if you need to rebuild it you are gonna need access to parts and i never heard of much in terms of parts unless your gonna goto ford? Which could cost you.
