So the the question is to follow the
RearRight FrontLeft RearLeft FrontRight (1)
or
RearLeft FrontRight RearRight FrontLeft (2)
I would think the (1) way considering the brake line is connected to brake proportioning valve the same way, regardless AUDM or USDM.
But then it could be the (2) because the BMC is on the other side.
Confused ??
Does anyone has a AUDM service manual?
Reason: mess up the description
BENJ is correct,this is the Australian industry standard.
CRXer,they might want you too bleed it that way due to the duel circuit for brakes,some cars run front to rear and other cars run diagonal,front left and rear right as one circuit,so hence the bleed sequence,just a thought,peace out.
Reason: had caps on
