If you want to actually 'learn' a stud pattern-
1) take off a wheel- on an EG you can see 4 bolts.
2) take a ruler and measure from the centre of one bolt to the centre of the diagonally opposite bolt.
You will find that on an EG the distance between these two points is 10 cm (or 100mm)
