Behind the wheel of my car, cruising the hills of adelaide
ED6 Civic
wider tyres does not mean more traction, it only means more stability due to the wider contact patch (contact patch deforms, contact patch doesnt actually affect grip in dry weather). it is as e240 says, in an ff, the front wheels take all the load from braking, accelerating and cornering. the reason why they use wider front tyres is because it helps in reducing tyre temperatures by exposing more tyre surface to the air.
Current Performance Modifications to ED6:
not telling, but it involves a semi-quad carb setup, and lots and lots of compression.
