2007 Civic Type R perf. mods
Hi,
I just got a 2007 civic type R and was wondering what the best mods are out there to get some good power gains. Any recommendations?
H for Have a nice f%@# day
you might want to have a look at this thread from the UK, they have a list of mods and stuff for the type r
http://www.civinfo.com/forum/type-r/...pe-r-co-uk.htm
obviously modding your car depends on budget so just have a look at what the thread says and see how it suits your budget
Thanx for the link MangChi but it didn't work. Error 404: Page Not Found
worked for me but the page is blocked by my work site, have to check it when i get home
I may be schizophrenic, but at least I have each other
http://www.civinfo.com/forum/type-r/...e-r-co-uk.html
it was just missing the "l" at the end of "html"
when i went home i couldnt get mine to work either, with both links came up error 404
gee, I wonder why I didn't think to this earlier ahhaha
fn2 mod list taken from www.civictype-r.co.uk
From http://www.civictype-r.co.uk/forum/v...p?f=90&t=16708
MODS (items listed are in no particular order):
Air Induction:
Unless combined with a remapped ECU, air intakes will not make any significant gains on the k20z4. Fn2 Intake.. Help Please - HondaTech Australia Forums scroll down for more info on this.
1. AEM - Said to suffer from heat soak. - £132.77
2. Injen Cold Air Intake - video/sound clip.
3. ABP Powertek Stainless Steel - Said to suffer from bad heat soak.
4. Toda Sports injection kits - £1,665.00 - £1,971.00 http://www.toda-europe.com/catalog/inde ... th=180_253
5. JDM FD2R RRC Intake Manifold - Said to be a tight fit, but it does fit.
6. Spoon 70mm Venturi throttle body - Said to be a tight fit, but it does fit.
7. HKS induction kit - In development.
8. Culasse's short ram intake - The modified mass airflow sensor tube gives correct air/fuel readings while eliminating the shortcomings of a CAI. viewtopic.php?f=17&t=167719 - 300EUR
9. PIPERCROSS Air filter induction kit (inc heat shield) £129.50 inc vat
10. POWERTEC Air filter induction kit (including heat shield) £145.00 inc vat - Filter seems too big for the provided heatshield, meaning the filter will sit diagonally. Also, the MAF tube is made of metal which can't be good for heatsoak.
11. Team Dynamics induction kit - £435
Exhaust:
1. Milltek - Sounds beautiful, but power gains are almost non-existant until 7,500rpms, where a few HP are gained, but only a few. - £495 inc vat with discreet tail pipes, £545.00 inc vat with 3" round tailpipes
2. HKS full exhaust systems - £650-700
3. Blueflame Performance exhaust system
4. JTune catback exhaust system - In development
5. Team Dynamics Stainless steel exhaust system - Full system available, manifold (+ de-cat or Sports cat), and a cat back system, all interchangeable. Mounts on existing road car mounts. Power increase and prices not yet confirmed.
Suspension:
1. Eibach progressive spring kit - £151.29
2. Front camber bolts - £13.00
3. Fast road geometry set-up - Adjusting camber, caster, and toe.
4. HKS Hypermax III Sport damper kit - £1,285.00
5. OMP Front & rear strut tower braces - £78.72 & £58.75, respectively.
6. Rear camber/toe shims £6.00 each
7. KW Variant 1 Coil-over suspension kit (pre-set dampers, adjustable height) - £580.00 inc vat (ABP Motorsports)
8. KW Variant 2 Coil-over suspension kit (adjustable rebound dampers, adjustable height) - £769.00 inc vat (ABP Motorsports)
9. KW Variant 3 Coil-over suspension kit (seperately adjustable bump & rebound dampers, adjustable height) - £949.00 inc vat (ABP Motorsports)
10. ABP -30mm Sports lowering spring kit £150.00 inc vat
11. Team Dynamics spring and damper upgrade - Ohlins fully adjustable – price & availability dependant in interest in this product.
Engine internals:
1. Toda High power connecting rods - http://www.toda-europe.com/catalog/inde ... 80_252_254 £1,180.00
2. Toda High compression piston kits - 12.1:1 £695.00, 12.2:1 £770.00, 12.3:1 £770.00. http://www.toda-europe.com/catalog/inde ... 80_252_255
3. Toda N1 high compression piston kit (13.6:1)
4. Toda 2150cc stroker kits - £2,305.00 - £2,690.00
5. JTune Extreme kit - In development.
6. JTune Ultimate NA kit - In development.
7. Hondata heat-shield gasket - £50.22
8. Spoon magnetic sump plugs - £24.10
Forced Induction:
1. JTune Supercharger kit - In development.
2. JTune Extreme Supercharger kit. - In development.
3. CPL Supercharger Kit - Produces 291hp at the wheels - £3549
ECU/Electrical:
1. Hondata Group N Civic Type-R ECU reflash - This sets the rev limit to 8,600rpms, and lowers VTEC engagement to 5,400rpms, and 3,800 if you're at full-throttle / wide-open throttle. - £548.94
As of now, K-pro will not work.
2. B106 Carbon Fiber battery - This will save you 12-13kg over the front axle for about £150. It will not be able to handle aftermarket amplifiers/sound systems, but will open up a good amount of extra space in your engine bay.
3. Team Dynamics Piggy back Engine ECU - This is still in development though the final product is imminent, it is on our development car at the moment. They are anticipating the final product twinned with the exhaust system and induction kit to achieve an increase of 45 BHP from the standard car. This does not involve anything more than the ECU and brackets, there are no internal engine modifications required.
Brakes:
The front brake pads are the same kind as used on the S2000 and the AUSDM DC5. The rears, though, are unique to the FN2.
1. ABP - larger than stock brake kits can be bought for a lot cheaper than the stock brakes.
2. Powerslot front big disc up-grade - £313
3. Ferodo DS2500 front pads - £76.24
4. Ferodo DS2500 rear pads - £tbc
5. Goodridge S/S brake lines - £tbc
6. Team Dynamics Brake Kit - Calipers, 4-piston road specification types with a black or red finish. Discs, Ø330x26mm thick, 48 cooling vanes, 8 grooves per brake face, bolted to alloy bell centres. Ferodo DS2500 pads, Hose adaptors to convert standard Honda hose to suit APR caliper hydraulic feed. Brake fluid, 1Ltr high temp DOT 5.1. All mounting bolts, washers’ nuts etc - £1500 + vat
7. Rotora Big Brake Conversion - Available in 4 or 6 pot front 330mm/355mm discs and 2 pot 330mm discs rear. Available through xopowertuning.co.uk.
- 4 pot 1 piece 330mm front £1151.
- 4 pot 2 piece 330mm front £1695.
- 4 pot 2 piece 355mm front £1950.
- 6 pot 2 piece 330mm front £2120.
- 2 pot 330mm rear £1340
Transmission:
1. Quaife LSD - The Quaife LSD from other k20 motors will fit the FN2. - £525.00
2. Toda hi-power clutch/flywheel kit - £630.00
3. Competition Clutch twin plate clutch/flywheel kit - £812.50
4. Toda organic clutch kit - £355.50
5. Toda lightened flywheel - £270.00
6. Team Dynamics Limited Slip Differential - £525
Exterior Modifications:
1. Honda OEM front and rear diffusers - ~£800, can be had for cheaper if bought from places like eBay.
2. Team Dynamics BTCC body kit -
- Front bumper - £650
- Pair of front wings - £450
- Pair of Rear arches - £350
- Pair of Sill extensions - £150
- Rear wing – available on request.
- Inner door cards
Misc.
1. Team Dynamics Roll Cage
Page 2 of this thread has a detailed list of JTune's products.
Hello all,
James at JTune just wrote me an email and attached a detailed list of their products in development and some which are already available (teaser: their standard centrifugal supercharger kit is available now). Enjoy:
JTune FN2 Dual 2.25” Cat back Exhaust System for the Honda Civic FN2 Type R
The JTune FN2 Dual 2.25” Cat Back Exhaust System with converter b-pipe is able to be bolted straight up to the OEM header and cat. The JTune FN2 Dual 2.25” Cat Back Exhaust System is designed for maximum possible flow across the entire length of the system, whilst also providing a unique exhaust note due to the dual setup. The JTune system allows over 4” of total volumetric flow of exhaust gasses to the rear mufflers, allowing maximum performance for both naturally aspirated setups and forced induction. The system comes with interchangeable road and race rear pipes, allowing owners a simple DIY changeover for depending on the desired use. The road rear pipes include extra mufflers to reduce exhaust noise over the race setup. Also included in the system are high quality polyurethane exhaust hanger mounts insuring rigid exhaust hanging position.
The JTune FN2 Dual 2.25” Cat Back Exhaust System is the perfect addition for the Honda enthusiast only wanting to mildly modify their Civic Type R for a performance gain and unique exhaust note. However, the system also performs extremely well in conjunction with the JTune FN2 Mild Re Flash.
Both the JTune FN2 Dual 2.25” Cat Back Exhaust System and the JTune FN2 Mild Re Flash can be upgraded in the future to support both the JTune FN2 Extreme and Ultimate kits providing customers with the ultimate performance package.
Availability TBA
Price
Exchange / FN2 ECU TBA
Replacement FN2 ECU TBA
JTune 160kw FN2 Extreme Kit for the Honda Civic FN2 Type R
The JTune 160kw FN2 Extreme Kit has been developed to provide the complete package of JTune’s common naturally aspired products including the JTune Cold Air Induction Kit, JTune Header and JTune FN2 Dual 2.25” Cat Back Exhaust System. The principle behind the JTune FN2 Extreme Kit is to provide enthusiast with the pinnacle of naturally aspired technology in the form of optimally designed bolt on modifications designed specifically for the Honda FN2 Type R.
When modifying any vehicle with the goal to create maximum power and throttle response it is very important to insure that all parts in conjunction, this is even more important for naturally aspired vehicles. To enable maximum efficiently of all bolt on products JTune has developed the Extreme Kit which provides the very best bolt on modifications combined with precision and perfect tuning to create an extreme package guaranteed to bring an extreme rush of performance to every FN2 owner.
The Extreme Kit includes the JTune Cold Air Induction Kit which positions a forward facing 3” K&N Extreme Filter in the lower left hand guard of the FN2. The position and design of the Induction Kit allows maximum amounts of acceleration forced fed cold air into the engine. To accommodate the Cold Air Induction Kit JTune have designed a JTune Battery Relocation Kit which positions the battery in the standard air box position, allowing more flexibility to produce a maximum free flowing intake which feeds the coldest possible air into the engine, providing extreme performance.
The JTune FN2 3” True Stainless Steel High Flow Cat is designed for high performance with maximum flow and incorporates a twin reverse collector allowing for maximum ground clearance.
The JTune 160kw FN2 Extreme Kit also includes top and bottom 4 pile silicon radiator hoses to replace the standard rubber hoses. Silicon hoses insure optimal cooling and coolant flow under all race conditions.
The key to harness and uniformly extract the power from the Extreme Kit is The JTune Extreme Re Flash. JTune have specifically designed this Re Flash to take full advantage of all common 98 octane fuels. Used in conjunction with the JTune bolt on products the Re Flash is a highly refined tune which delivers an extreme transmission of power and torque throughout the entire power band. JTune have lowered the VTEC cross over point from 5400 to 3400 rpm and fully remapped 4800 fuel, ignition and cam angle points. The JTune Re Flash combined with the JTune bolt on products produces extreme performance increases throughout the entire rev range and increases throttle response dramatically.
JTune FN2 Extreme Kit Overview
JTune FN2 3” Cold Air Induction Kit including silicon hoses, clamps and K&N filter
JTune FN2 Battery Relocation Kit including mounts, nuts and bolts
JTune FN2 Header including gaskets, nuts and bolts
JTune FN2 3” True Stainless Steel High Flow Cat including gaskets, nuts and bolts
JTune FN2 Dual 2.25” Cat Back Exhaust System including gaskets, nuts and bolts
JTune FN2 Interchangeable Race Section
JTune FN2 top and bottom replacement radiator silicon hoses
JTune FN2 Hondata intake manifold gasket
JTune FN2 Extreme Re Flash
JTune FN2 polyurethane exhaust hanger mounts.
Availability TBA
Price
JTune 170kw Ultimate Kit for the Honda Civic FN2 Type R
In conjunction with Toda Racing Australia JTune have developed a Custom Spec J Toda Cam Shaft package designed for use with JTune’s bolt on products for the FN2. The JTune Ultimate Kit builds on Extreme Kit and delivers the ultimate naturally aspired experience for the FN2 Type R Civic. The Ultimate Kit, based on the Extreme Kit includes the addition of the Custom Spec J Toda Cam Shafts, a set of Toda K20 Valve Springs and a Toda Timing Chain Tentioner. The Toda Spec J Cam Shafts have been designed to insure maximum possible power and torque throughout the entire rev range when used in combination with the Extreme Kit. Toda and JTune have designed the cam shafts to have an extremely low VTEC cross over point of 3500rpm, providing linear VTEC power all the way past red line. JTune have also provided with this kit the JTune Ultimate Re Flash which harnesses and uniformly extracts the power from the Ultimate Kit. The Ultimate Re Flash takes full advantage of all common 98 octane fuels combined with a highly refined tune and delivers the ultimate transmission of power and torque throughout the entire power band. JTune have lowered the VTEC cross over point from 5400 to 3500 rpm and fully remapped 4800 fuel, ignition and cam angle points.
The combination of the JTune’s bolt on products combined with the Spec J Cam Shafts and Ultimate Re Flash produces the ultimate driving experience and totally transforms the FN2 Type R throughout the entire rev range.
JTune FN2 Ultimate Kit Overview
JTune FN2 Ultimate Re Flash
JTune FN2 Toda K20 Valve Springs
JTune FN2 Spec J Custom Toda Cam Shafts
JTune FN2 Toda Cam chain tentioner
Availability TBA
Price
JTune 180kw Standard Supercharger Kit for the Honda Civic FN2 Type R
The JTune Standard Supercharger Kit is designed for those who wish to keep the FN2 looking and sounding completely standard with the addition of a 30% increase in power and torque across the entire rev range. The Standard Supercharger Kit can also be upgraded in the future with the addition of The Extreme Kit, transforming the package into The Extreme Supercharger Kit, proving a further 25% increase in power and torque.
The JTune supercharger is a centrifugal supercharger which harnesses its power and torque from each rotation of the engine’s harmonic balancer, driven by engine RPM. This intern provides instant throttle, power and torque response throughout the entire rev range. The JTune Supercharger Kit delivers a very linear power delivery which creates more power and torque the more the engine is revved, providing a very smooth and drivable delivery of excess power.
The JTune Standard Supercharger Kit comes complete with everything required for the bolt on process, including complete engine management and injectors and all the required nuts and bolts.
Our JTune Standard Supercharger Kit Overview
JTune FN2 Hondata Intake Manifold Gasket
JTune FN2 Toda Cam Chain Tentioner
JTune FN2 Supercharger Standard Re Flash
JTune FN2 Supercharger Intake Manifold
JTune FN2 Supercharger Belt Tentioner
JTune FN2 Fuel rail spaces and studs
JTune FN2 Air-conditioning relocation adapter
JTune FN2 Centrifugal Supercharger including mounts, gaskets, hoses and belts
JTune 660cc Injectors
“Quote:”
Adrian Norton – Toda Racing Australia
“The car screams like an angry pig whilst on the dyno”
Availability On sale NOW
Price’s
JTune Extreme Supercharger Kit for the Honda Civic FN2 Type R
The premier JTune FN2 package is the Extreme Supercharger Kit. Not only does the enthusiast get all the benefits from the JTune Extreme Kit but also JTune Supercharger, providing a mind boggling 55% increase in peak performance above a standard FN2 Civic Type R.
The JTune Extreme Supercharger Kit is by far the most radical package developed for the FN2. The JTune Extreme Supercharger Kit delivers a combination of extreme increases of torque and power supercharged by a centrifugal supercharger throughout the entire rev range. This package delivers instant power at any engine RPM or throttle position.
The Extreme Supercharger Kit transforms the FN2 to a new level of performance suited for both daily driving and intense track use.
JTune FN2 Extreme Supercharged Kit Overview
JTune FN2 Supercharger Extreme Re Flash
JTune FN2 Supercharger Belt tentioner
JTune FN2 Centrifugal Supercharger including all mounts, gaskets and hoses and belts
that is alot of info....and i dont understand half of it, but good to know i can get stuff now, ill have to get a techy to explain it all in noobterms lol.
i like the sound of the elec which lowers the vtec level tho, that would make a huge difference
Thanx for all the info guys. I managed to find JTUNE too. The extreme pack sounds awesome but they said they won't have it for another 3 months and it will be around $13K. So it's not cheap. They are located in Melbourne but have people in Brisbane who can do the work. For now I'm gona do coil-overs and I have already tinted the windows.
JTUNE is a joke...3months means 3 years
yea they said 3 months last november i think... not its august
