Does anyone know what is the difference between IG1 ACG & IG1 HAC? I want to plug a device via the internal fuse which needs to go the ignition. Am I on the right track?
This is the description:
Easy-installation to connect the interior fuse box.
Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
thanks heaps
