Results 1 to 5 of 5
    Nov 2015
    Canberra
    2012 Euro CU2
    CU2 Project Mu replacement rotor/pads - don't fit!
    I purchased some Project Mu CRD front and rear rotors as listed in the application guide on the website
    http://www.project-mu.com.au/en/prod...des/rotors.htm
    and some NS400 brake pads
    http://www.project-mu.com.au/en/prod...ides/honda.htm
    I have a 2012 Euro and these parts do not fit. The rotors and pads are smaller all around and the pads are the wrong shape.
    My front rotors are 320x32 and rear 305x9 and the PMU are 300x28 and 280x9.
    I think these might fit a gen 7 CL7/9.
    Does anyone know if the early CU2's (2008/9) have a smaller brake setup?
    My front calipers are two piston but I have seen a TSX CU2 vid on YouTube that are only single piston.
    So be warned anyone thinking of these PMU items, I don't know how I will go getting a refund on this stuff...
    All aus specs cars have 320mm front disks.
    No matter of year and come with 2 pistons. Usa tsx will have 1 piston and not sure of size but its smaller.
    CU2 Auto ECU Flashed Finally extra power
    Nov 2015
    Canberra
    2012 Euro CU2
    Ok, well in that case the PMU listing is completely incorrect and should not specify CU2 at all.
    Nov 2015
    Canberra
    2012 Euro CU2
    Just to follow up on this, PMU Australia were happy to refund or exchange the parts.
    Sent from my iPhone using Tapatalk
    Aug 2012
    Adelaide
    06 Euro Lux
    Quote Originally Posted by Kuchiki81 View Post
    I think the 300mm and 280mm is for the 2L variant?
