Results 1 to 9 of 9
    May 2008
    Honda Civic EK
    Rubber Seal on door/window Replacing
    ]Hi Guys,
    I need to replace both sides of the seal in the below image as its been damaged from the sun. What's the name of this part? and has anyone replaced these before? if so how difficult is it?
    Dec 2008
    835 Beaufort St
    hondie 2000
    easy to get out.
    Also easy to just paint with a rattlecan
    hehe.
    PHC
    Dec 2010
    South Sydney, NSW
    FD Civic Modulo
    I ended up shaving all the black bits off on the EK back in the day.
    May 2008
    Honda Civic EK
    Yeah might shave it all off and spray it. but just wondering roughly how much they would cost?
    Aug 2009
    Front yard
    4WD 89 Concerto
    about $10-20 for each side at wreckers, takes about 1 min to change.
    I got a mint set from the wreckers for free lol
    OEM parts whore
    May 2008
    Honda Civic EK
    How does the part come off?
    Aug 2009
    Front yard
    4WD 89 Concerto
    you remove the plastic door pillar trim, held in by 3 screws.
    Then wind the window down and use your hands to pull it off, it needs a little force but it comes out easy. Pull it upwards and towards the end you will need to slide it out a little.
    OEM parts whore
    May 2008
    Honda Civic EK
    Where is this plastic door pillar trim, held in by 3 screws. next to the side mirror?
    Aug 2009
    Front yard
    4WD 89 Concerto
    no on the other side, you can see it in the bottom left of your first photo
    OEM parts whore
