Results 1 to 12 of 12
    Oct 2014
    Millicent
    Honda Accord
    When shall i do a Auto Gearbox change & Flush on a 2011 Accord Euro.
    Hi Guys. Does any body no when i should do a Auto gearbox flush on my Honda 2011 Accord Euro. Only done 30,000 kys. & does this gear box give trouble like the early models & what is the recomended oil i should use in the motor..I want to use Penright 0w- 30 synth but need to no is this ok.
    Dec 2008
    835 Beaufort St
    hondie 2000
    what does your owner's manual say?
    hehe.
    PHC
    Oct 2010
    '03 Euro [CL9]
    whatever the manual say.
    then halve it.
    2003 CL9 5AT *ECU REFLASHED*
    Jun 2012
    Perth
    CD5 & GE6
    Do it now if you want to keep the car for a while
    Just 2.5-2.7 litres of DW1
    And you're set
    www.OzAccord.net/forum
    Oct 2014
    Millicent
    Honda Accord
    OK DW1 Honda Trans fluid. GOT IT. But to flush it shouldn't i do it several times to clear all the old fluid out of it & does the transmission have a filter i have to change. Thanks Guys.
    Jun 2012
    Perth
    CD5 & GE6
    Just do a drain and fill every 100kms, just at least do it 3 times
    And the filter is under the air intake, behind the battery on top of the autobox
    Youll see the pipe and filter
    Honda do sell it
    There is a DIY on here on how to change it
    Oct 2010
    '03 Euro [CL9]
    you can do this 2 ways:
    1. do a 3x3 change every 80k km
    2. do a single fluid change every 20k km
    Oct 2014
    Millicent
    Honda Accord
    Ok guys. Thank you for the info. Excellent. grate Fourum It's a pleasure to be here.
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    then halve it.
    this.
    BMW say their trans are fill for life, which is full of shit.
    best possible, drain & fill every 20k
    SSpamily
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    Quote Originally Posted by Lozer View Post
    if only 30k on the clock, just drain and fill every 20k.
    should keep it newish enough
    SSpamily
    I would do a drain and fill every 30k. This is what the tranny fluid looks like at only 30k.
    Normal day to day driving.
    Oct 2014
    Millicent
    Honda Accord
    Yes I did mine at 32,000 kys & it was just like that & the magnet was realy full of gunk.. I did a full flush by draining& fill 3 times no she is good to go for a nother 30k
