Ok, Im new and Im also young. I was wondering how much you could increase the capacity on a 1.6L Civic engine? Could you get it out to as much as 2L? Anyone want to throw any rough prices around? What other things do you need to do after doing this? Im guessing you'd need a new ECU.
Thanks for helping the newb
no no no NO. This has to stop.
Before ANYONE new asks a question - USE the SEARCH function - im sure this has been asked before.
*lock*
my apologies, after a look around on the forums for what seemed hours i still havent found it. do you know the name of the topic or can u post the link to it for me please? Much appreciated.
MAte - sorry for the discreet "shove off" but have you used the search function at all ?
Go to www.honda-tech.com and do a search there first...learn all u can and then come back here when u acquire more knowledge.
(BTW as a general rule , any engine cannot be bored out to more than 200cc than its stock capacity)
dude, chill out on the man about the search function, u dont have to reply if u dont wanna help. everyone starts out as noobies man.
Anyway dude, the bore and stroke can be used to increased to almost any size except the limit that is placed physically by the cylinder walls (how thin it can go before cracking) and the stroke length (how tall the motor is).
I have seen 1.6 been bored and stroked to 2 litres so physically yes they can be done, but the price will knock u off ur feet.... stroker kits usually set u back 1,800 to 2,500 somewhere along there, and then ud need to pay someone to do the machining of the sleeves to fit in bigger bore pistons.
not cheap dude, would be chaeper to get a b20 block and resleeve that for strength
thanks alot pornstar, thats the sought of price i was thinking it would be.
*lock*
And how are new people meant to learn with a reply like that?
Did you even bother doing a search and posting the relevant link here?
No.
Don't bother posting useless shit unless you plan on helping people such as this new member.
Thanks Andy.
Hope that helps Jacko. Don't let any of the members here discourage or intimidate you.
nah im way out of line man, as eknine said, if u teach a man to fish, u feed him for a life, i gave this man a fish, i think he's gonna be all fvcked up yo, cos he cant do a search function.
little do these guys know how different the power is from the states to aus dynos, the tracks, the amount of bullshit u can spin. But if u do a search yo, u can find all the magical answers in the land of honda-tech.
anyways peace ima go tell some noobs to go search, looks like alot of fun dawg :P
Everyone's entitled to their own opinion, BUT, this thread was started by someone seeking knowledge/information so let's keep the thread to answering his question.
Thanks.
Being the obvious pro you are mate , you failed to see that it was myself that said that old proverb. IF you had searched , you would of discovered this. :P
MY point in quoting this old "pauline hanson" line is - if we were to answer this particular persons question with more optimisim than careful thinking - then we lead this person on a futile journey. Its imperitive that everyone here searches , and learns for their self in their own time- there is no use telling someone how to do it , as they will not understand what they are doing, and possibly result in a negative experience .
But out of every person here i have helped him the most - showing him a website with a much larger database of knowledge to learn from !
Best of luck Jacko.
buy a b16a head ( unless your current engine is a b engine )
buy a b20 block
buy a vtec conversion kit so you can use your b20 block with ab16 head
do a quick rebuild on the block ( rings bearings and gaskets water / oil pump )
some nice ARP head studs... andyour good 2 go for a b20 2.0L civic.
I recomend Hondata for the ECU, no wiring changes no sensor changes plug and play.
Regards James
buy a b20 block
Regards James
Thanks alot, could you give me a rough price for this? It sounds pretty costly, I was guessing maybe 6- 8? Thanks again James.
