Thanks for the help TB, will hve the engine ready mid next week, so hopefully get it back before the xmas holidays, but i highly doubt it -_-"
the old saying is: "haste makes waste"
so just go with he flow ;)
and good luck :)
TB, that website is ****ing ace.
Just read through this whole thread, it's good knowledge for myself. I'm looking to do a B20 setup in the next week or so and I just wanted to know if I went by this list should I be ok? Is there anything else I would need besides an ECU and GB?
B20B8 block
VTEC water pump
B18C timing belt
B20B head gasket
ARP head studs
ARP rod bolts
oil line and fittings
head work (dowels/plug/surface)
piston relief work
PCV system (fittings/hoses/can)
Coolant hoses
VRS gasket kit
b16a head
ITR camshafts (or larger)
ITR valve springs
ITR intake manifold
Larger throttle body
Lightened flywheel
Heavy duty clutch
Adjustable cam gears
Adjustable fuel regulator
Upgraded fuel pump
Oil cooler
(copy and pasted this list from a post on this thread)
Thanks
wow, that is a pretty good list!
but you also need to check things like the condition of the driveshafts, i usually get them reconditioned at the same time if the boots are starting to crack...
also check the engine mounts...
Hey guys, is it alright to run 2 sanwich plates?
I got the vtec conversion sandwich and would like to add another for an oil cooler....
why would you recondition drive shafts these days it cost 200 bucks for a pair
from Honda?
Oem Honda shafts are mega expensive!!!!
But they are one of the best shafts you can get. Hasport ones use rubbish metal and brake easy.
repco bursons clutch brake australia burt brothers fairfield everywhere mate,,,
not genuine obviously
FYI, the new spring style LMAs from honda are just $16 each, worth changing when you are reconditioning your heads.
how often have you had an LMA fail?
Not fail, but if they not spring type lma then they get quite rattly over time.
are not all LMA's a 'spring' type?
http://www.cccylinderheads.com/pics/LMA1.jpg
My b16a has the enclosed style one (dunno if there is spring inside, think it's a damper with oil in it). The type r or spring style is obvious cos you can see the spring cos that's all it is.
I have the new style at home to change over soon. My lma's so rattly below vtec lol.
yeah, they cased ones have spring inside.
B16A/B18C = old cased style , S2000 = "new" spring style
i guess it is much cheaper to make the spring one, rather than the cased one?
well, $128 is *kinda expensive* to replace things that in most cases will not be broken?
sure, for example i replace old heater hoses before they blow "for peace of mind", but these are actually not expensive compared to a puddle of coolant on the side of the freeway and a cooked head...
but in the case of an LMA - it can be broken and you'll still drive home/continue racing...
the real question that should be asked is - do the new style offer advantages when used with high-lift cams?
Im just providing information about it, people can decide for themselves.
As for advantages, I do not know, but the new engines are using this style anyway, and it definately looks more robust.
I changed mine because one of my LMAs came apart and instead of forking out $76 for 1 old one, I decided to pay 128 and get 8 new ones.
Also, I was surprised by the price as I read the Americans are paying USD$30 for one...
oh, OK, i must have misunderstood where you said that these parts are worth changing when we are reconditioning our heads...
so what part number did you buy?Quote:
was it either of:
14820-PCB-003
or
14820-PCB-305
these LMA's.. do they NEED to be changed/reconditioned when I put my head into the shop??? Also does or has anyone in Bris done a B20 setup and if so where did they go to get there block and head work done/places people would recommend?
no...
just wondering what timing belt cover you guys are using?
ive got a b16 head + b20b3 block... but my mechanic doesnt know which cover 2 use just had 2 rebuld the head after a rock got in there nd stuffed my tensioner...
*note* not running a Timing belt cover atm
use the b20 or b18 one...
b16a is too short & will leave a gap...
the back cover that sits inbetween the timing belt nd housing?
ah, no i was referring to the timing belt cover - between teh timing belt and the engine mount.
for the 'back cover' that goes between the camgears and the head you need a VTEC one...
NB - you may need to modify the lower edges of the back cover to fit the b20 block if using a B16A back cover...
Vtec = b16a & b18c
hmmmm, thats strange, coz they had a b16 one, but they said it ddnt fit on the b20 block..
which main studs would be used for the b20 vtec? arp dosnt list a part number for the B20B all they have is this:
B16A: 208-5402
B18C: 208-5403
B18A/B: 208-5404
have tried emailing ARP them selves and they have no info they could give me:confused:
i always thought you were meant to change them, would you recommend using standard B20 main studs then?
no - you are meant to change the headbolts, not the mainbolts...
i dont think there is a strong reason to change the mainstuds on a non-boosted B20VTEC.
u mean the head studs? i found a link that shows exactly what you were talking about re-threading the main studs using the ARP fasteners.
can i use B16A main bolts or are they different size/thread?
no, i SAID: "you are meant to change the headbolts, not the mainbolts..."
FYI - Hondas are build with headBOLTS and mainBOLTS
you MUST change the B20B headBOLTS to either B18C headBOLTS or aftermarket headSTUDS...
you can do what ever you like :)Quote:
but i have already answered your question if you bothered to read my posts...
thanks for clearing it up.
Well normally people dont for a b20vtec build.
Anyway, my new oil pump looks likt the one on the right, and my old oil pump looks like the one on top left.
Timing belt cover cant fit, anyone knows what cars run this timing belt cover that would fit?
http://www.tamparacing.com/forums/at...ns-oilpump.jpg
Thanks,
Leon
the one on the right looks to be a B16A oil pump, the left might be B18C.
everyone running with non standard bottom end, what compression do you guys have?
^tuned on 98 octane ?
12.7 running 98 octane
12.5:1 on 98
hey ive got a question im doing a b20 build now im running cp 12.5:1 pistons eagle rods stock b20 crank for the bottom end and ive got a jdm b18c itr head and i wanted to run stage 2 or 3 skunk 2 cams and valve train...has anyone ran this setup or similar and had issues with valves touching or anything similar??
thanks
Clay the motor to check clearance
take it to PM or you will be banned.
so far wenever i say to someone im building a b20 up all they say is there so unreliable n it will blow....how many people have had problems with there builds? and is this just a assumption because the motor was never made for vtec?
If you build it properly eg. Apart from decent pistons and rods use 5 cap girdle, decent dampner like fluidamper, balance everything and don't rev past 8,500rpm should be ok.
All comes down to the quality of the build and not reving it past 8,500rpm.
